MJ Ref 200 question
P
Pinoy
I am about to buy this sub and planning to use it with Denon 2106 reciever;
My questions, Is Denon 2106 is good enough to support my sub or do I need to go higher (Denon 3805) ?
Thanks . . .
Knyght_byte
more to the point is which amp suits your main speakers......for a sub it wont make so much difference......its only outputting either a low level signal or a few strand cable of hi level.......but for your main speakers they may benefit from a better amp with better surround and power capabilities.....
(personally i'd always say go as good as your budget can get you providing the price hike is worth the increase for the rest of your equipment)
P
Pinoy
Thanks, If that the case my other option is to change my sub to MJ Ref 100 and upgrade my amp tp 3805. In this way I will get a better sorround sounds.
Trending threads
