Mj Pro 50
Discussion in 'Home Cinema Speakers' started by jiml, Apr 7, 2002.
  1. jiml
    jiml
    Mar 31, 2002
    Paignton
    I have just got the small PRO 50 and can't decide whether to keep it or not. If I add a second one, will it give me lower frequencies (like the PRO100 is claimed to be).
    For music it is good and integrates with my mission 734i's well. For movies it definately adds depth, but not at the physical level - ie I can hear but not feel it. For around £600 what is the recommendation; REL or Paradigm Servo 15? (or 2*Pro50)
    What is the entry point for THX?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Adding a second MJ Acoustics Pro won't give you deeper frequencies but will probably give you better sound quality.
    Ask Nic Rhodes about the Servo 15 as he swears by them but don't forget that they are big beasts. They will give you much deeper bass that you can feel but at the expense of half of your living room.
