MJ Acoustics Reference 100 with Linn Komponents
daformah
Hi all
I currently have a set of Linn Komponent 5.1's
Im replacing the sub and was looking at the MJ Acoustics Reference 100
Should i be looking bigger or will this pack some decent punch?
Thanks in advance
Chris
Badger0-0
Consider these first.
Sub Woofers
You'll see some very strong similarities to the MJ's, at much cheaper prices, if you look closely ;)
Badger0-0
£120?
No, you can't beat that.
Second hand, it's probably a fair price :smashin:
Would the Gemini II be of similar quality etc?
No.
It's probably better :eek:
Slightly more power in a slightly bigger box.
Forget MJ's claims that the 100 goes down to 13hz, as frankly, that's a bleeding insult, imo.
Guess who used to make the MJ's? :rolleyes: ;)
Enough said ;)
Badger0-0
Tbf, if £120's your current budget, I'd take that MJ if it's working perfectly and in good nick.
I can't see you losing out when you come to sell it.
asdonk
I would go for the Gemini II , it has a 10 inch woofer
against the MJ which uses a 8 inch woofer (MKI)
Podcast: CES 2021 Special - Sony, LG, Panasonic, Samsung, TCL and Hisense TV news and more...
