MJ acoustics Ref100 v. BK XLS200
Discussion in 'Subwoofers' started by user34, Sep 2, 2004.
  1. user34
    user34
    Any one been able to do this audition ?
  2. mugsy
    mugsy
    Nov 1, 2002
    687
    Kent
    +20
    I would be interested in this also - is anyone able to comment? :lease:
  3. mugsy
    mugsy
    Nov 1, 2002
    687
    Kent
    +20
  4. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    I'm gonna be buying a sub soon and these were the two I was considering - shame you can't demo the BK.
    What about the REL Quake? Does anyone know how this compares to the Ref100 (these are two subs I can demo)?
  5. user34
    user34
    Is the Sidney Acoustics AR-12, it's made in Israel and his limited marketing in France.
    http://www.sidney-acoustics.com/ar12.php
    Be patient with the link it can be slow. It sells for c. €500 in France, which puts it broadly competitive with the XLS200.
    Basically a down firing slot loaded refelx cabinet about 41cm*41cm*44cm and with a 200W amp. It's getting good comments on the French AV forums.
    If any here know it, please chip in.
  6. mr. shr
    mr. shr
    Jul 26, 2004
    450
    +8
    I tried both of these and decided the XLS is the clear winner. It performs much better and is considerably cheaper. What more could we possible ask for?
  7. swartzy
    swartzy
    Apr 16, 2001
    9,505
    Northern Ireland
    +697
    I have the MJ Acoustics Ref 100 and it's a great little sub that is very controlled fast and I am happywith it's performance......I have the Ref 100 on low level phono to phono connection Tannoymx10 hooked up to my centre speaker (as suggested by MJ acoustics site) via speaker cable
    (high level) output to sub.....The results have been very good and I am amazed that my centre channel has come alive as described on the MJ Acoustics site...didn't even need a neutrik lead....
    The Ref100 is great on both movies on low end and very fast at keeping up with music....the control it has means a very tight bass authoratative but never booming.....my room size is approx 4 metres by 3 metres....
    my system is
    Tannoy M3 FRONTS
    Tannoy M3 REARS
    Tannoy MR FRONT EFFECTS
    Tannoy MC Centre
    Tannoy MX10 SUB (hooked up to the centre via speaker cable)
    MJ Acoustics ref 100 (hooked via amp via low level phono sub lead)
    Yamaha AX2 Home Cinema Amplifier
    Sony 905 MR dvd player
    Panasonic 610 video
    Ecosse reference Producer Digital coaxial Lead
    Qed Sqart leads
    Cabletalk 3.1 speaker lead
    QED speaker lead
    hope this helps
    regards
    swartzy :thumbsup:
