MJ accoustic PRO 50 - any good ??
Discussion in 'Home Cinema Speakers' started by dfield2000, Jul 25, 2002.
  1. dfield2000
    dfield2000
    Jul 16, 2002
    957
    Cardiff
    +5
    I've been recommended the MJ acoustic PRO 50 sub from a sevenoaks salesman, but I'm having trouble finding a review of it. Can anyone recommend it ?
    I'll be buying some B&W 602 S3 for the front and a LCR60 centre channel at the same time. (I'll use some old mission speakers for the rears for the time being). I saw a one line summary for the PRO 100 in a mag, but it said that it was 100w so I'm thinking that maybe the PRO 50 is a little under powered.
    cheers.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    What Hifi reviewed the 50 and 100 and gave them both five stars. I heard the 50 at the Bristol show and was quite impressed.
    The wattage doesn't always relate to sound levels as my old 40watt Q Bass filled a large room adequately as does the Q50.
  3. Big Jim
    Big Jim
    or alternatively...
    How about the small Velodyne sub in the power buys forum? £325 for something at least equivilent of a REL Q150. If I wasn't skint, I would be having one.
  4. HouseofMu
    HouseofMu
    Jul 18, 2000
    377
    UK
    +13
    I've recently bought a Pro 100 and can't praise it highly enough.
    I demo'd the Pro 50 but decided the double power output would be better suited to my room (18ft x 15ft).
    n.
