Mixing speakers with diferent impedances
Discussion in 'Home Cinema Speakers' started by fermonro, Nov 8, 2004.
  1. fermonro
    fermonro
    I'm thinking about buying a JBL SCS 178 surround system (speakers with 4 ohm), and then improve it replacing the frontals with 2 JBL Xti80 speakers (6 ohm) and the center speaker with 1 ATX10 (6ohm).
    Is it possible to mix speakers with different impedances? What do you think about it?
    Thanks in advance for your help.
  2. Mr Ess
    Mr Ess
    Oct 27, 2004
    1,293
    48
    Preston, Lancs
    +38
    I've just bought a pair of Wharfedale Pacific evo 30 floorstanders which are 6ohm and the matching centre speaker in the range which is 8ohm so I guess the manufacturers aren't bothered.
