Mixing Q and ST series
Discussion in 'Subwoofers' started by derekn, Apr 12, 2005.
  1. derekn
    derekn
    Jun 8, 2004
    692
    28
    Bristol
    +37
    Given that the Q is best for movies and the ST for music, has anyone tried mixing the two?
    I'm toying with the idea of connecting an ST by the high level inputs, thus I imagine "Direct" mode would be a kind of "Direct plus Sub" on CD replay.
    If I also connect a Q by the low level inputs (and maybe the ST as well) then these would operate when the .1 LFE signal was present, eg DTS movie.
    Any comment/advice on this idea will be most welcome!
    Thanks,
    Derek
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    I'm not sure that I would agree with your "given" as I feel that the ST range are better all round subwoofers than the Q range and I doubt whether any Q sub ( I have never heard the Q400 ) is better than my Storm was.
    As a matter of interest do you already have these two subs or are you thinking of buying a pair.
  3. derekn
    derekn
    Jun 8, 2004
    692
    28
    Bristol
    +37
    Hi Ian,
    Rel told me about the concept of ST/Music and Q/Movies so I accepted their opinion.
    I have a Storm 3 and a Strata 3 at present; will try the Storm with a Q400E next week and report back.
    Regards,
    Derek
  4. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    I think that's marketspeak in order to sell more Q subs. In reality the AV market tends to be less fussy than the hifi market and the main appeal of the Q150 and Q200 over the ST range is their compact size.
    I think that you may be disappointed if you replace the Strata with a Q400 as you won't be getting much extra for your money.
    I upgraded my Storm 3 to a cheaper SVS sub and the difference was quite profound as the American sub is louder, deeper and audibly distortion free.
  5. derekn
    derekn
    Jun 8, 2004
    692
    28
    Bristol
    +37
    If anyone's interested :boring: :boring: , I've abandoned this idea. Not because of the Rels - because of my TMA Room Equalisation.
    If I connect the Storm via HiLevel then the "equalised/filtered" L&R signals are sent directly to the sub and the TMA filters on the sub signal are bypassed - a double detrimental whammy. This sounded inferior and a check with an SPL meter showed the sub resonances shining through :thumbsdow .
    If I connect via LoLevel and listen in direct plus sub mode then only filtered low freqs go to the sub and the response is flat :smashin: .
    So it's back to the drawing board and if anyone is looking for a Q400E, then look hard enough and you'll find a mint bargain.
    Derek
