Mixing Input and Output device into one.
opifex
Hey all,
I am using VoIP software that only takes one input to broadcast (the mic). I want to also broadcast my computer audio (such as music) while my mic is also continuing to broadcast.
Does anyone know of any kind of solution that can mix output sound and input sound into one input device which I can then select in my VoIP application?
exoticBoarder
It is possible to do it.
Go in control panel
Select sound
Go in the recording tab
right click on the devices and select show disabled devices
A stereo Mix device should appear. Enable it.
That should mix your audio out with your mic input.
