Answered Mixed Framerates
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by TheShadowman, Jun 18, 2015.
  1. TheShadowman
    TheShadowman
    Mar 25, 2011
    243
    +17
    Hi All
    I have just finished a 30 minute film which doesn't look great. On investigation I discovered that somehow, and I really don't know how, I had about 50% at 50fps with the rest at 25fps.
    I don't want to re-film the whole thing for obvious reasons, so can somebody suggest the best way to render for the best results under the circumstances.
    Thanks in advance
  2. Best Answer:
    Post #3 by TheShadowman, Jun 18, 2015 (1 points)
  3. noiseboy72
    noiseboy72
    Apr 24, 2011
    6,271
    +1,897
    50fps and some frame blending if the action is reasonably fluid, or 25fps if it's more active and the shutter effect is not too noticeable.
  4. TheShadowman
    TheShadowman
    Mar 25, 2011
    243
    +17
    Best Answer
    Thank you very much, I'll give the 50fps a go.
  5. TheShadowman
    TheShadowman
    Mar 25, 2011
    243
    +17
    Thank you again, noiseboy72. 50fps worked a treat
