Mix and matching MS speakers!
Discussion in 'Home Cinema Speakers' started by Trent., May 2, 2007.
  1. Trent.
    Trent.
    Nov 22, 2006
    851
    28
    Essex
    +64
    Ok, i currently have ms 302x4 and a 304 center +sub,set up which performs very well.
    I have just bought a set of ms 902's bookshelf, 904's floorstanders and 905c center from a friend that hardly used them from new?
    Now what i intend to do is run the 904's and 905c at the front and 302's rear with the 304 center rear, for a 6.1 set up. I'm hoping this is going to be a decent upgrade and that the sound match will be good.
    The only thing i've noticed is that the 9 series speakers are 8 ohms and the 3 series speakers are 4-8ohms, is this likely to be a problem and should i set my amp to 8ohm?
    Currently my set up is packed away due to some long winded re-decoration, although the need to hear my new speakers may speed things up:D
