Mitsubishi 28" picture problem
Discussion in 'General TV Discussions Forum' started by chedmaster, May 9, 2005.
  1. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    i am almost set on getting a Toshiba 32ZP48P, unless the problem i have on my current crt is fixable.
    its quite an old 28" mitsubishi wide crt tv (about 5 or 6 years old i think) and used to produce a fantastic picture, especially through RGB, and still does, apart from whenever there is something light on a dark background, the lightness drags across the whole screen from the object right over to the right hand side of the screen. is this fixable, (in a service menu for example) or is it just that the set is old?
    many thanks
  2. JayCee
    JayCee
    Jan 20, 2004
    22,331
    Lanarkshire
    +2,328
    Model no?
  3. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    CT-28BW2B
    thanks for your help
  4. JayCee
    JayCee
    Jan 20, 2004
    22,331
    Lanarkshire
    +2,328
    It sounds as though the crt is on it's way out.......is it not as bad if you reduce the contrast?
  5. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    dam just blew some of the cash that was going towards a tele on a sub, when you say on the way out is it likely to break fully? the problem hasnt really got worse since i recieved it from the parents living room.
  6. JayCee
    JayCee
    Jan 20, 2004
    22,331
    Lanarkshire
    +2,328
    No, it should just get worse over time, it may go on for a few years yet.
    Good luck :hiya:
