Missions - Which ones
sparkymarky
which ones???????????????
IanW1977
OOPS
Link is helpful !!
sparkymarky
well don't know a great deal about first two packages (although i believe the cinema 7 was more acclaimed than the cinema 6).
The m70 got good reviews when it came out (a whathifi product of the year).
however with the m70 you get a m7c centre but the new m7c2 is supposed to be a lot better.
It may better to buy similar speakers to the m70 range seperately. You can get the bassier m72 for £90, the m7c2 for £110, and m7ds for £130 which comes to £330, roughly the same price, although no sub.
You could then add a decent sub (if u need it) at a later point.
Either way the m70 is still a good package.
As an aside, i have had problems with ordering from qed
IanW1977
Thanks a lot for that.
Shows What happens When you Shop Around.
I was Chuffed at getting some for £262.00 But then Saw some for £197.00, but thanks to your advice, Have Placed an Order with Empire Direct for £179.92
A Saving of £82.08.
