Mission Sub.
Discussion in 'Subwoofers' started by takamine, Nov 23, 2004.
  1. takamine
    takamine
    Hi,we have got a sony tafb940,amp,running into mission m51 speakers. we need more deep bass, & were thinking of adding a mission ms8 sub. the sony has two sets of speaker outlets, & can be switched on together. can i use this sub & if so how do i wire it up. thanks, :confused:
  2. Tony8377
    Tony8377
    Aug 19, 2004
    954
    Essex
    +4
    Modern home theatre receivers have an LFE (low frequency effects) channel that provides only low frequency signals for an active subwoofer.
    However your amplifiers does not have a low level subwoofer output. Therefore the only means of output is from the main left and right speaker channels. However to do this your subwoofer must feature a "High Level" input which I don't think the mission does but you will need to confirm. Try and check the specs to see if it has a 'High Level Input. If is does simply connect the subwoofer using normal speaker cables outputting from the second set of speaker outputs on your amplifier to the "High level" inputs on the sub such as this. .
    Some subs high level input is through a neutrik speakon connection such as the attached thumbnal so you need a special lead. See this thread for more info. If you need more info you will get a lot more responses in the subwoofers thread :)
  3. recruit
    recruit
    This should really be in the Subwoofer section :)
    John
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    If your budget can stretch a little further, have a look at the Mordaunt Short MS309 which is available at £220 (or maybe even a bit less now). This was the winner of a group test by What Hifi here and can be connected to your stereo amp by attaching it to the speaker terminals.
    It should be leagues ahead of the Mission subwoofer
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    If the Sony amp has pre-outs (not tape outputs) then a low-level signal could be used and would probably be the preferable method.
