Mission speakers
Discussion in 'Home Cinema Speakers' started by mulder, Mar 5, 2003.
  1. mulder
    mulder
    Dec 9, 2002
    146
    Can anyone help! I need to replace my old set of rear speakers but cannot afford the mission M7ds so I'm looking for a set of rears around £90. I would like to buy Mission rears if possible because I already own the Mission M7c1 and M73 floorstanding Speakers but I'm struggling to find anything in that price range. I was toying with the Mission M70 bookshelf speakers but i'm not 100% sure if they would be suitable as rears, does anyone know if the M70 are suitable or should I be looking at another make?
  2. EvilMudge
    EvilMudge
    M70s make great rears in an M7 system. For those who prefer direct radiating rears they're the surround of choice, and I think Mission even recommend these for use as the surround backs in and EX setup.
    TBH I thought they were about the same price as the M7DS though?:confused:
  3. rjw
    rjw
    Sep 6, 2002
    204
    Bath
    +5
    I'm quite happily using Mission 70's (the predecessors of the M70's) as rears with M74/M7C2 front's.
    I might "upgrade" to M70i's if they came up at the right price, but have no real need to replace the 70's.
  4. alextgreen
    alextgreen
    Apr 17, 2001
    550
    London
    +5
    M70s (or their cheaper Denon badged twins) are excellent little speakers. I was blown away by just how much noise comes out of such a tiny box!
  5. garry_brock
    garry_brock
    Hi Mulder,
    I think if you check Richer Sounds you may well find the excellent 77ds rears in there for £99...... half original selling price.
    Failing that, i think that hi-fi-junkies are doing the m7ds for £69 at the moment
    Hope this helps.
    Garry
  6. Sandman
    Sandman
    Nov 28, 2002
    3,566
    Glasgow
    +1,271
    I have the same M73 fronts and M7c1 centre speaker set up as you and recently added the 77DS rear speakers. These speakers sound great although it took a while to find the perfect place to position them. I got them from richer sounds in edinburgh and they still have a couple pairs left.
  7. mulder
    mulder
    Dec 9, 2002
    146
    Thanks for the help guys! I checked out richer sounds but you can only purchase m77ds in their stores only and I don't live close enough to one of their stores, does anyone know where else I can find the m77ds rears? If not I might buy the mission 70's from QED for £82 unless anyone knows of somewhere cheaper.
