mission query
Discussion in 'Home Cinema Speakers' started by s9s, Feb 3, 2002.
  1. s9s
    s9s
    Hi all
    Im new to home cinema, and have just invested in m72 cinema package. I have just at te moment set up the front two and centre. My query is which is the best way to mount the rear m7ds? There are no brackets or wall mounts supplied, also I have those damn plaster board walls. Any advice much appericiated.
    Regards
  2. lidders
    lidders
    Dec 19, 2001
    97
    9
    beverley
    Cavity worms!
    Either metal or plastic you use a drill to screw them into the wall then use the supplied screw to fix. My kitchen fitter told me about them they use them to hang MFI units!!
    Just used them for my 77ds's
    Can get them from B&Q etc.
  3. s9s
    s9s
    Thanks, that was i was thinking as well, but needed to confirm.
  4. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    That is an extremely excellent idea. Cavity worms. Screw Fix is a god send. Very, very sturdy.
