mission m7x v m3x?
Discussion in 'Home Cinema Speakers' started by sarll, Nov 4, 2003.
  1. sarll
    sarll
    Mar 19, 2002
    1,393
    63
    +126
    Has anyone demoed any of the M3 series speakers yet?
    Finding info hard and haven't been able to get my nearest av store in a while.
    Are the M3's technically a replacement/upgrade on the m7 range or could they be worse?
    Any feedback welcome.........
  2. adi
    adi
    they are a replacement on the m7 range
    i am considering buying from this range when i upgrade
    looked at them at the manchester show and they looked a good quality, well made product with a good range of sizes / applications throughout the range - but i obviously couldnt demo them at the time
    the m35 fronts which i am considering are a 3 way design and are apparently "getting to the dealers round about now"
    if you demo any in the meantime, i'd be interested to hear your opinions
    adi
  3. sarll
    sarll
    Mar 19, 2002
    1,393
    63
    +126
    cheers adi.
    Hopefully i'll get a demo at the weekend.
    I'm also interested to see if the new entry centre (m3c1) is an improvement over the the old M7c1 - as that was a bit of a weak link before. I prefer the slimmer design of these centres but may be forced to look at the larger m3c2.
