Mission M7DS
Discussion in 'Home Cinema Speakers' started by smallman28, Apr 13, 2002.
  1. smallman28
    smallman28
    I wonder if anyone can help me.I have recently purchased some secondhand Mission M7DS speakers and was wondering if someone could either post on this group or email me a scan of the
    diagram that comes with them to drill the fixing holes to hang them on the wall.I know its not rocket science to figure out but just cant help feeling there might something I miss for some bizzare reason!
    Thank you
  2. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    I bought them new and there was no template included with them
  3. Dr.Rock
    Dr.Rock
    Jan 10, 2002
    694
    London, UK.
    +38
    I have a pair of Mission M7DS. Can someone please tell me what's a good cable to use with them, without spending too much money than necessary? I'm using QED Silver Anniversary for my fronts (2 x M72's & M7C1), but it'll empty out my bank account if I buy that cable for my rears (because of how far my rears are away from the amp!).
    Thanks.
  4. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    I use Ixos 607 which is flat and has a self adhesive coating on one side which makes it easy to slip under the carpet. The official price is about £1.99 a metre but there is a chap on Ebay that sells it much cheaper.
  5. mrblue
    mrblue
    Mar 2, 2002
    65
    I've just mounted my M7DS's on my walls you only have
    to use the top set of mounting holes which are 28cm
    apart {centre to centre}
    I hope this info helps.:)
  6. Dr.Rock
    Dr.Rock
    Jan 10, 2002
    694
    London, UK.
    +38
    Ian-J,
    Thanks for the recommendation. I'll look into it. Is the Ixos 607 better sound quality than, say, the Ixos 607 (flat self adhesive) or the QED Micro (these two wires are normally recomended for rear speakers by dealers).
    Thanks.
  7. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    The flat cable replaced some very cheap cable and I noticed an increase in sound level. I didn't audition anything else as this stuff seemed ideal in both price and construction
