Mission m7ds rear speakers
Discussion in 'Home Cinema Speakers' started by aqureshi, Oct 21, 2001.
  1. aqureshi
    aqureshi
    I need to fix these speakers to the corners of my living room. Can any one recommend what is the best way(cost effectiv as well) of achieving this.
  2. riddler
    riddler
    Just fit two 2*1" battons across the corner gap.
    cut 45 degs at each end then screw them to the wall at each end through the 45 deg part.
    Should cost you almost nothing :)
  3. aqureshi
    aqureshi
    Thanks for the help, My wife is not happy fixing the speakers in the corners, instead she wants straight on the wall, i.e one side (vertical)touching the corner. Is there any harm putting these speakers straight on the wall. I only need to screw in 4 screws.
  4. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,231
    UK.
    +2,767
    When I tried some Eltax HT2s in the corners of my lounge, I found they acted very much like monopoles - I think this was because a lot of the sound was being reflected from the corner along the back wall.
    Try placing them there temporarily to see what they sound like - it'll probably be quite good with two walls getting the rear effects from each speaker.
    Gary.
  5. riddler
    riddler
    I have mission m7ds's and the best postion for these speakers is on the back wall. Especialy if your sofa is against the wall.
    set then about 1.5 meters from the ground and half a meter or so in from the sides.
    Sound great there. :)
  6. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    What Riddler said...
  7. aqureshi
    aqureshi
    Thanks Riddler, How about 2.3m from the ground. How did u fix yours. I was thinking screwing 2 screws and just hanging the speakers on those. OR id u buy any brackets.
  8. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I installed mine over the weekend ( on the side walls) by screwing two screws directly into the wall amd hanging the speaker on that. They come with some stick on "feet" to stop the speaker touching the wall directly.
    It isn't always easy to try out a rear speaker like the M7DS before installing it as it means that you need a couple of people to stand there holding them whilst you watch a some films.
    One of mine is on the side wall and only a couple of inches from the rear wall whilst the other is on the opposite side wall about eighteen inches in from the rear wall.
    Sounds good to me and once they have run in should sound even better.
    Ian
  9. riddler
    riddler
    Just two course screws with large heads straight into the plaster board. (they are not heavy.)
    And that does the trick.
  10. riddler
    riddler
    Dont forget if you need them higher up the wall, you can turn then upside down so the higer fequencies come in your direction and not into the ceiling.
  11. aqureshi
    aqureshi
    Thanks Ian and Riddler for your valuable advice. I will be installing them high (about 2.3m from the ground) on the wall. My walls are concrete so need to drill. Thescrews you have mentioned Are they any special or I can buy them from any DIY(size?). Upside down means the logo will be upside down. Is that correct?
    By the way which cable did you use. My local Shop person told me that use either 42 or 78 strands sas I have to buy at lease 28-30 meters. Are these cables OK for the rears.
  12. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    use any screws as long as the head is big enough to slip over the thingy on the speaker.
    I used Ixos 607 flat cable at £1.79 per metre from hifibitz as I wanted to run it under the carpet but there has been an interesting thread in the last couple of days on uk.media.home-cinema newsgroup where the consensus of opinion is that expensive speaker cable is a waste of money and ordinary wiring cable is just as good. Some of the arguments are technical and way over my head but have a read and make your own mind up.
    Ian
  13. riddler
    riddler
    I use qed original (qudos) cable sounds ok to me costs £2.5 per meter but i paid £2.
    Its not as flexible as it could be.
    I suggest looking at the cable ian suggests.
    The ixos 607 low profile, its flexible and comes with sticky backing too.
    I also beleive that all this silly priced cable buissnes is crap. I could certainly never hear the diferences that certain mags claim to.
    Still each to there own.
    as long as you a reasonable cable i think youll be fine.
    p.s
    yes your logo will be upside down and i dont think it can be turn around.
    Mission have thankfully made provision for the speakers to be mounted either way up.
    Just check the heads of the screws you want to use in the slots.
    And when you work out the required length dont forget the extra distance the rubber mounting things add.
    [ 23-10-2001: Message edited by: riddler ]
  14. Luc
    Luc
    Aug 7, 2000
    420
    You all forgot that the best thing about the Mission m7ds is that you can turn the logo upside down. :D
  15. aqureshi
    aqureshi
    The logo is stuck quite hard to the speakers. How did u manage to change the logo upside down
  16. Luc
    Luc
    Aug 7, 2000
    420
    Mine wasn't stuck at all, it just sits there with a plastic spike keeping it attatched. Moved very easily. Pull it a bit harder and it'll come out eventually.
