Mission M73 Sub
Discussion in 'Subwoofers' started by paiger, Jun 12, 2002.
  1. paiger
    paiger
    Any opinions? I've got the chance of getting one cheap. I don't have a sub at the mo and I'm looking for a cheapo one until I can afford the Ruark to match the rest of my system. Under £100 sounds good so second hand looks the way to go. I can't find any info on the above model so any help would be appreciated.
    Steve
  2. paiger
    paiger
    My mistake, it's the 73ps. Anyone?
  3. S H A D O
    S H A D O
    Mar 16, 2001
    10,286
    United Kingdom
    +1,567
    Why not check out one of the Paradigm subs that RS have on offer at the moment. PDR10 is 120 quid and the PS1000 is 150 quid, over the budget but worth a look.
  4. stranger
    stranger
    if i remember correctly the mission 73ps is a passive sub. don't touch it with a barge pole, follow jase's advice.
  5. paiger
    paiger
    Thought it looked a bit cheap. Saw it on Ebay for £25 with no bids but very little info. I emailed the seller but not heard yet and I can't find any info elsewhere on it. I will of course be looking for an active sub. Thanks for your help.
    Steve
