Mission M72 Or Fs2 Av
Discussion in 'Home Cinema Speakers' started by romored5, Oct 29, 2001.
  1. romored5
    romored5
    I need help, My budget enables me to buy either the FS2 AV or the M72 (but I can't aford a sub), My room is of a average size.
    Do I really need a sub with the M72's ?
    What are the FS2AV like for quality and bass ?
    Which would be the best option ?
    I dont have the cash for the kef 2005's
    I'm thinking of pairing either set with a Marantz 4200 amp, would this be ok ?
  2. riddler
    riddler
    These are very diferent speakers giving a very diferent sound.
    They cant be compared to be honest. you will have to go listen to them and deside what you like best.
    Personaly i could live with the flat pannels. They are definatly convienance over quality of sound.
    Although mr zzr might say different.
    Excuse my poor spelling ;)
  3. riddler
    riddler
    P.s you ALWAYS need a sub with home cinema. ITs just that you can get up and running without it whilst you save your pennies.
