Mission M70as Sub
Discussion in 'Subwoofers' started by aqureshi, Jan 20, 2002.
  1. aqureshi
    aqureshi
    I am thinking of buying the above Sub to go with mine M73s set.
    Has anyone recently bought this. Are there any problems with this. Are there other sub in the market which are in the same price range and are better than Mission.
    Asad
  2. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    While the M70 speaker series is fantastic and my personal favourite, I would not think of buying this sub.
    In my opinion, any decent sub will demand at least £500 new. If not, it's not worth having. Do yourself a favour and try to find yourself a second hand REL, that would cost at least this amount new. A sub does not need to tonally match your speakers, it's just bass, and REL is the best bass you can get.
  3. aqureshi
    aqureshi
    where is the best place to look on the net for 2nd hand and which model od rel.
  4. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Check the classified ads here and elsewhere.
    Try asking Spectre... I get the impression he's very up with his subs.
