Hi, Am thinking about buying the mission M35i's which will be used for music not AV, have a fairly large room so the size isn't a problem, can anyone comment on the sound?? Thanks
I have M35's which I use for both AV and music, they a brilliant for the money(£280) although they did take a long long time to fully run in(200-300hrs at moderate levels i reckon). If you have them to close to a rear wall then the bass can become very boomy and it will sound like the midbass is missing. Although the midbass level does get alot better as they free up. I run mine with the foam baffles in the back as I dont have the room to pull them right out from the wall and this seemed to balance all the bass out correctly for me. Go have a listen to them and see what you think but im very happy. ~Dan~
