Mission M2S Speakers Wall mount bracket?
Discussion in 'Home Cinema Speakers' started by steveh2001, May 27, 2005.
  1. steveh2001
    steveh2001
    Jan 5, 2005
    173
    Just got some M2S speakers, but cant find on the web the wall mount bracket for the rear speakers, it doesnt list the model number of the bracket anywhere!
    Anyone know where to get these? Or where they are nice and cheap :smashin:
  2. missionman
    missionman
    The M2s speakers are threaded to take the standard Mission wall bracket m30BR - you can get these from any Mission M3 stockist, or ring our customer services if you have a problem.
    Mr Mission
  3. steveh2001
    steveh2001
    Jan 5, 2005
    173
    Thanks Mr Mission! Didnt see this post!
    Have contacted your customer services recently and got a very friendly response and was told which brackets to get as you say the M30BR worked perfectly!
    Had a follow up question - was thinking about using stands for the front speakers - what stands are compatible with the m2s speakers?
  4. bu5ter
    bu5ter
    Oct 17, 2004
    2,152
    63
    Egham
    +116
    Hi Steve just a quick question Im looking at getting the M2S system is it any good? What size room are you using it in??
