Mission M Cube Vs Kef Kht 2005.2
Discussion in 'Home Cinema Speakers' started by jacedevil, Jun 3, 2005.
  1. jacedevil
    jacedevil
    I Currently Have The Kef's But Am Looking To Upgrade To The Missions (girlfriend Requires Small Speakers, So Dont Suggest Larger Better Speakers).
    Has Anyone Any Experience Of The Missions B4 I Make The Switch.
    Any Thoughts Or Advice Welcome.
    Jacedevil
  2. Neil Fellows
    Neil Fellows
    Apr 6, 2004
    301
    Wonderful with movies and DVD-Audio, not so hot with 2 channel music. And they just look so damn nice...
    If I can offer any advice, i'd say steer clear of them with Denon amps as they can sound a little too warm and slightly muffled with music.
  3. jacedevil
    jacedevil
    Cheers, i do not usually use them for music and the amp is a sony stb 930.
  4. Neil Fellows
    Neil Fellows
    Apr 6, 2004
    301
    In that case - go for it! You will not be disapointed. There are some great reviews of them out there at the moment.
  5. skinnyfat
    skinnyfat
    Any particular reason you are upgrading ??
    Skinny
  6. jacedevil
    jacedevil
    i hope they will sound better and i know they look better!!
  7. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    I'd upgrade to a new amp instead. The Sony is a bit long in the tooth and for £1000 you could get a very nice, new box. The Kef's aren't brilliant, but you'd likely get a better sound together with a new amp.
    The Missions are more of a sideways step IMO.
  8. jacedevil
    jacedevil
    i still want the missions, so which £500 av amp would you go for??
    cheers
