Mission FSAV2 -> Kef Q1's and Q9c upgrade?
Discussion in 'Home Cinema Speakers' started by yimpster, Jan 13, 2004.
  1. yimpster
    yimpster
    Dec 21, 2001
    309
    +15
    Hi peeps,
    Was wondering if anyone had any opinions on this upgrade. I'm in the process of decorating our lounge, which gives me an opportunity to change my speaker setup.
    I've got a Denon 2802 with the Mission FSAV2 speaker/sub combo. I've also got a set of Kef Q1's on my hifi which aren't really used for anything other than computer games.
    Any recommendations on putting the Q1's on stands with the Denon amp and getting a Q9c or Q6c for the centre? I was planning on letting the Missions handle the rear channels for the time being.
    Is this going to be an improvement? if so which speaker is more suited to my needs the Q6c or Q9c?
    Cheers for any ideas or feedback in advance.
    Many thanks
    Adam
  2. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    Well I doing the same thing, except I'm going from KEF Eggs to the Q1 and Q9c setup with Egg rears, I haven't heard the Mission setup but I think they are the flat panel version aren't they?
    Well the KEF Eggs have long been considered one of the best sub sat AV packages in the sub 1k bracket and in comparision I thought the Q1/Q9c blew them away, so compared to flat panel speakers it should be a hell of an improvement, but you'll already know that as you already have them, when it comes to the choice of centre, I'd say go with the Q9c as this has the same internals and speaker drivers as the Q1, Q5 and Q7 where as the Q6c has the same as the Q4 and Q compact which are cheaper and of a lower spec/further down the range.
    Ryan :smashin:
  3. yimpster
    yimpster
    Dec 21, 2001
    309
    +15
    Cheers for your feedback Ryan, anyobdy else have an opinion on the upgrade?
    Adam
  4. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    Just do it - you must already know how good Q1s are, add the centre that matches best (Q9c) and voila massive improvement across your front soundstage.
    When you decide to add decent surrounds then the compacts could come into your thinking (I have them & they're great)
  5. yimpster
    yimpster
    Dec 21, 2001
    309
    +15
    Ok - sounds great. Any opinions on mounting these babies? Brackets, shelves or stands?
    If stands, any recommendations on a no frills good performer that won't dent my wallet too much
    Cheers chaps n chapesses
  6. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    Stands
    Mine are on Partington Focus at about £50 a pair - Sturdy (part sand filled) and look good (single column in black looks good with the Qs with no grille)
  7. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    Well I think I'm going for the Apollo A2 (2 columns) or A3 (3 columns) stands, they look great in silver with the Q1's and they have a large top plate for good stability as the Q1's seem quite big, they can be sand filled for extra stability and apparantly better sound or so its said.
    They're 49.99 from Superfi and I'll be trying to get a fiver or so knocked off as I'll be buying the speakers at the same time.
    Ryan :smoke:
  8. EasyTiger
    EasyTiger
    Sep 12, 2003
    63
    9
    Bournemouth
    Just to let you know I have recently done a similar upgrade, and the difference is amazing!
    I originally had old KEF Chorale III (mid 80's speakers) as the left and right, with the Mission FS1 centre speaker, and the other four FS1's around the back for 7.1.
    Have now got Kef Q5 and Q9c at the front with the FS1's around the back.
    Whilst the Q5's are very good, it's the centre speaker that I have noticed the most improvement. The soundstage is much smoother and balanced (which is quite logical I suppose).
    Whilst putting Kef's around the rear would be ideal, due to space restrictions I need the flat panel's around the back and these are supporting the Kef's really well.
    Edit:
    One thing to watch out for is that if you only have flat's at the back then your sub may switch off temporarily when watching tv. If there is nothing below 80HZ (or your crossover setting) and nothing below 260HZ in the rear then the sub doesn't see a signal when the TV program is a lot of talking (this assumes you are using pro logic on your stereo tv signal). I haven't noticed the problem on any films yet it just seems to be when using stereo sources.
  9. bobbypunk
    bobbypunk
    if you like the fs2's apparently you can join a 2n'd pack on and connect them directly to the amp, freeing you up to replace the sub which is the only real weak part of the pack.
    The only reason i'd suggest this is that you can pick up fs2 packs for a fraction of their worth!!
  10. yimpster
    yimpster
    Dec 21, 2001
    309
    +15
    Hmmm - i've tried connecting the FS2's directly to my Denon 2802. To be honest the sound is terrible compared with it wired through the sub. Maybe it's just my config but surely there's a reason that they've been designed to plug in this way.
    My plan is to keep the FS2's and sub powering the rears and use the Kef Q1's and Q9c for the front.
    Hopefully replace the rears and sub eventually, not sure if i will though as i quite like the depth of sound i get with just the Q1's plugged in. Guess it comes down to personal taste in the end..
  11. yimpster
    yimpster
    Dec 21, 2001
    309
    +15
    Any comments on the SOUNDSTYLE XS122 ? They look pretty smart and just fit into my budget.
    Cheers chaps
  12. FazerThou
    FazerThou
    Aug 23, 2003
    1,898
    Bath
    +149
    I think you will find that the crossover in the su is around the 240Hz point. There is something about it in te mission manual if I remember correctly
  13. yimpster
    yimpster
    Dec 21, 2001
    309
    +15
    OK chaps really need some opinions before i shell out some hard earned cash on these stands.
    It's really between the following.
    1) SOUNDSTYLE XS122 @ £99 from superfi
    2) ATACAMA NEXUS @ £69.99 (in silver) from superfi
    Does anyone have any good or bad experiences with these, especially if you've got a pair of Kef Q1's on them.
    Would like to order tomorrow if poss - so keep those opinions coming in.
    Cheers again for all your help and guidance
    Adam
