been reading this
Wiring up the FS2 is a piece of cake too, thanks to Mission's own 'umbilical cord', which connects to the speaker and sub outputs on the back of your AV amplifier at one end, and the FS2-S sub at the other. The satellites all plug into the sub via Mission's flat, low-profile speaker cable. If you take time setting up the FS2-AV properly, the whole system is so unobtrusive, it's almost invisible.
do its connect to a normal amp ??
