Mission FS2-AV & TV
Discussion in 'Home Cinema Speakers' started by darrenf, Feb 28, 2003.
  1. darrenf
    darrenf
    May 19, 2002
    164
    +3
    I have the Mission FS2's which are great when watching DVD's, the only problem I have is if I listen to anything from SKY through my speakers. I hard to describe but the really lack something - it seems that they are very bright with nothing in the middle, no warmth - so much so that the TV sound seems much better, much more solid. Like I say it's hard to describe and I hope this makes sense. Has anyone else encountered this and if so is there anything I can do or is this one of the drawbacks of this system.
    Daz
  2. Sgt.Colon
    Sgt.Colon
    Darren.
    I have the FS2's and I can't say I have noticed. Is it just from your Sky box you are lacking or Terestrial TV and video too? I will give it a listen tonight when I get home and report back my findings. :smashin:
  3. AndyCCC
    AndyCCC
    Dec 10, 2002
    27
    London
    I'm clutching a straws a bit here - but last time I reconnected my FS2s I managed to get main L&R out of phase (mixed up + and - on one of them). Took me ages to work out why I had virtually no bass unless I switched the balance to the left or to the right. Could something similar be happening?
  4. Sgt.Colon
    Sgt.Colon
    Darren.
    Have given it a go and I have to say it sounds fine to me. I would just try cheicking your setup. :smashin:
    Hope this helps. :)
