mission fs1
Discussion in 'Home Cinema Speakers' started by jelly, Oct 17, 2003.
  1. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    does anyone know the reason the fs1 speakers go from the amp =sub -speakers if i raqn them straight from the amp would there be any difference???
  2. timlloyd
    timlloyd
    Jan 15, 2003
    278
    Warwick
    +9
    The FS1 and FS2 speakers generally cant produce a response below 240Hz, therefore when you feed the mission sub a full range signal it extracts those frequencies and pushes the rest to sats.
    I had an e-mail recently from mission saying you could connect them direct but be careful how hard you drive them. If you connect them direct and only have a crossover of say 80hz on your amp you will be losing a lot of signal!
  3. Arshad
    Arshad
    My son was playing around and he suddenly pushed one of my large speaker and bang it fell on the floor.
    Would the speaker easily damage or break if they fall once or twice?
    I checked the speaker nothing has been broken and the sound is still ok but still not sure.
    Any ideas?
