mission fs1 extra panel
Joined
Oct 1, 2003
Messages
1,306
Reaction score
Points
366
Age
46
Location
nottingham
as above to make my 5.1 into 6.1 but cant find anywhere that sells single panels tried e mailing mission but i think it must be work experience week thanks as always
Do you have the 6.1 enabled Sub? Remember that the panel must be wired via the sub in order for the frequency below 190Hz to be directed to the sub.
As for an extra panel, I think most stockists of the FS1 can get hold of an extra panel for you. Give LE Concepts or AV Land a call.
no will run the extra speaker from the amp and the auto setup on my pio will do the rest
As far as your MCACC handling things, it will detect that the panel is Small and then it depends on what you're setting your crossover to. On my Pioneer VSX-D2011 I can select 200Hz, so if the 912 can also do this then you should be fine (as it doesn't matter whether the other speakers are set to Small or Large as both low and high are going via the sub).
The BIG PROBLEM With Your Home AV System EXPLAINED
Back
