Mission Dipole Speakers (eg M5DS)
Discussion in 'Home Cinema Speakers' started by TimHiFi, Feb 18, 2005.
  1. TimHiFi
    TimHiFi
    Feb 2, 2005
    84
    Reading
    Mission says that you can hang these dipole speakers 'upside down' on the wall (the brochure for the M5DS says that anyway), and provides the keyways for doing so.
    If you do this the 'Mission' logo on them will b upside down. I was wondering if you could remove the name plate and turn it through 180 degrees ?
    Has anyone tried this ?
    Tim
  2. innercry
    innercry
    May 10, 2004
    67
    Midlands
    Ive got the 77DS rears and did try to see if the logo would move but to no avail. I have a feeling it would be the same for all.
  3. Astaroth
    Astaroth
    Jun 22, 2004
    2,254
    48
    London
    +97
    There are supposidly some versions where the logo is attached by a pin and so it is possible to pull it off and then invert it. I have the M7ds and it would appear that they are glued on and so no options for switching
  4. TimHiFi
    TimHiFi
    Feb 2, 2005
    84
    Reading
    Hi Guys .... official response from Mission ....
    "The badge is actually held on by 2 pins which push into the grille, it is possible to re-position it by using double sided tape!"
    I think I'll leave well alone then :0)
  5. iaria
    iaria
    Dec 7, 2003
    108
    16
    Crawley,West Sussex
    Hi there I have the M5DS and they are hang upside-down and YES the mission badge does come out to be turned the other way without double sided tape
    Gerry
  6. simonrad
    simonrad
    Feb 9, 2005
    35
    Manchester
    hi there, I am considering these speakers but so far have not managed to find out much about them, can you offer any advice, did you compare with any others before you bought them?
    thanks
  7. Dean
    Dean
    Jun 20, 2003
    2,690
    London
    +188
    I've got the 77ds and they are excellent, nothing to touch them when i first got them a few years back. Mission recommends placing them about 30 cms above ear height. Also to avoid confusion i think most if not all of missions generic rear speakers are in fact bipolar, not dipolar.
  8. Astaroth
    Astaroth
    Jun 22, 2004
    2,254
    48
    London
    +97
    I must admit that i bought mine as a natural match to my fronts and the fact that i wanted bipolar speakers to get a more enveloping sound from movies (dont listen to multi-channel music at all)
    Whilst I didnt audition them I am very happy with them (when the kids damaged my last pair I was in no doubt I wanted the same to replace them)
