mission ctr needed to match
Discussion in 'Home Cinema Speakers' started by Taz, Apr 16, 2001.
  1. Taz
    Taz
    what member of the mission family of ctr spekers do i need to match my front 702's?
    :cool:
  2. robocop
    robocop
    Oct 16, 2000
    646
    Old Detroit a.k.a. Chippenham. Wilts
    +23
    The 702 is from Mision's 700 series.
    I currently use a Mission 70C2 and it performs very well.
    Most of the 700 series has been deleted and replaced by the M7 series.
    If you hunt around you may be able to get one at a bargin price.
    Also check out Mission's web site at www.mission.co.uk :)
  3. Guest
    When I was using Mission 702's I used the excellent 77C1, In fact I still use it with my Mission 780's. It's an excellent speaker and being the same make, it will match well with your 702's. It is around £190.00 but when compared to the other mission centres it definetly stands out.
    There is also a 78C from the 78 series but I could'nt really comment as I have not heard it yet.
  4. Radioactive__Man
    Radioactive__Man
    Jan 13, 2001
    948
    Scotland
    +18
    aren't Richer Sounds doing it for £150, or am I confused with their rear dipoles ?
  5. Guest
    It seems you are a little confused
    :confused:
    It's available from richer sounds for £179.00, which is cheaper then I thought. It's the 77ds rear's you mention which are cheaper.
    Good price mind!
    :D
