Mission 78 Series driver problems
Discussion in 'Home Cinema Speakers' started by JiMbOb_74, Jun 16, 2004.
  1. JiMbOb_74
    JiMbOb_74
    I have a full mission 78 series setup. Comprissing 782se fronts,78C centre,3 X 78ds rears.
    I have had the drivers on the centre speaker replaced less than a year ago under warranty because they where cracking around the cone. I noticed the other day while cleaning my system the same was happening again...Has anybody else had any problems with the same speakers/drive units. My 782Se's are over a year and have no signs of cracking... Is it just centre drive units with the problem?
    My local hifi shop are brilliant :clap: (www.acton-gate.com) :clap: and are sorting out with mission at the moment but was just wondering if its an isolated problem (eg is there something in my house causing the cracking.heat/funmes!?)
    Any info would be a great help! Thanks :lease:
    James
