Mission 77ds from Richersounds.
Discussion in 'Home Cinema Speakers' started by ELV, Jun 17, 2002.
  1. ELV
    ELV
    Jun 5, 2001
    690
    Up in the proper north
    +11
    I'm thinking of buying some white 77ds from Richersounds but i
    noticed that they never seem to be in stock,has anyone ordered
    them when they were out of stock and how long did they take to come?
    Also what are they like with a 2802.
    Cheers.
  2. stranger
    stranger
    richer have been out of stock of these speakers for weeks now, as mission have stopped making them and apparently have no stock left it's unlikely richer will ever get any more. some firms in the mag. ads. advertise them for about £140.00 if you wish to pursue them.
  3. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    I bought some from Richer Watford 2 weeks ago. I had heard a similar story, so jumped when they said they had some in stock. I asked them about continued supply, and they said that they'd been hard to get hold of since Christmas, but they come in in dribs and drabs - they checked, and the warehouse showed *some* stock.
    May be worth phoning around - the Watford store's number is 01923 218 888 - open 12 > 7pm. Always found them really helpful there.
    HTH
  4. Jarvo
    Jarvo
    Nov 30, 2001
    16
    I'm running a set of M7ds with a 2802, They're of similar design
    and regardless of which ones the better, they sound great
    anyway.
    Good luck
    Ant
