Mission 77ds bi-pole speakers help plse
Discussion in 'Home Cinema Speakers' started by allygash, Sep 29, 2004.
  1. allygash
    allygash
    just aquired the above speakers & would like advice on placement.
    I have a large(ish) size room with a high slanted roof(left to right). I had planned to put the speakers on the back wall about 15" up in the air(above the curtain rail), cause my sofa is up against the back wall. Is there any recommended location for these type of speakers?
    Rest of setup: pioneer 504/868/812amp speakers: mission 733i*2 front/mission 733 centre/rel strata III sub.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    I used to have mine about six feet above the floor but in my case they were on the side walls facing across the seating position aabout eighteen inches in front of the rear wall
  3. Brogan
    Brogan
    Oct 9, 2003
    7,476
    Cary, North Carolina
    +482
    I have these speakers now and they are mounted exactly as Ian has described.
    The axis of the speaker is in line with the seating position.
  4. Nick
    Nick
    Sep 27, 2004
    48
    Bedford
    I have these speakers and have had them on both the back and side walls. I personally preffered them on the side walls as well.
