mission 773e // mission 771 e// yamaha a2
Discussion in 'Home Cinema Speakers' started by krusty, Aug 14, 2004.
  1. krusty
    krusty
    on setting up the yamaha a2 i need to know do i set the speakers to large or small ...im a bit puzzled ive tried both settings and cant tell the difference :confused:
  2. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,905
    If you can't tell the difference it doesn't matter which way you set them. Normally one of them is clearly better than the other setting but not in every case.
  3. krusty
    krusty
    thanx for that info ian. im leaving them at all large.
