  • Black Friday Deals
    Visit our Black Friday page for our frequently updated, hand picked deals on TVs and other tech.
Mission 75 series problem
C227
Got mission 753's at fron with 75C centre speaker run by a Yamaha DSPA2 Amp.
The main sound great, but the centre channel sounds thin, very little bass, voices sound thin. Ive treid every setting butt hey still sound the same.
I thought these were meant to be a good centre speaker!
So what do I do? I want more weight and warmth but retain the excellent amount of detail they provide.
Which centre speakers are really good? I need something that either integrates well with the 753's OR something that has Main speakers in its range which are also excellent.
Parmenion
Ever thought of trying a second 75C?
If your using it underneath a 28" telly then cancel the above suggestion but if you have the room you could give it a try. I ran two centres (75C) side by side bi amped. Glorious sound.
regards
Parmenion
pragmatic
Is strange, as my 75C is very bass'ey. I have it set to 'large', if you have such an option it might be worth a try because when set to small i didn't like the sound at all.
C227
It might be set to small. I will check.
My room is 18 foot wide by 18 ft deep. Its sitting under a 42" Plasma. I might try a better support aswell.
Buying a second one......but then youve got two tweeters wuite far apart, unless u stack them in which case it might work quite well.
Will get back with my findings.
C227
Solved problem.
The setting on the yamaha was for large centre speaker. I decided to use small and see what difference it makes.
Result! I get much more bass now, much better vocals, the whole system has come together now and sounds amazing! I swithced back to large speaker and it sounded horrible again.
75C according to the Yamaha is a small speaker (well it aint massive). Goes to how that the settings do actually work and get it wrong and it wont sound right.
Thanks!
Parmenion
small and large are not refering to the physical size of the speaker, they are talking about its ability to handle full range signals or limited signals.
regards
Parmenion
