Mission 70ds bi-polar...any feedback?
Discussion in 'Home Cinema Speakers' started by damtom1, Mar 12, 2002.
  1. damtom1
    damtom1
    These seem to be quite well regarded in most of the info i,ve read.Richer sounds have them for just under a hundred quid.
    At the moment i,ve a pair of Yamaha NS-E80,s ,connected via Gale Hyperlitz.Will i benefit from the missions?How will i benefit?Any feedback welcome....CHEERS
  2. mansell
    mansell
    Feb 11, 2002
    914
    28
    Bristol
    +39
    buy the m7ds, these are fantastic
    I have these as part of my M72 package
  3. Dr.Rock
    Dr.Rock
    Jan 10, 2002
    684
    London, UK.
    +34
    HI Mansell,
    I too have the M72 package. Can you please tell me what cable are you using for your speakers (fronts and surrounds) ? I need to improve on mine, so I'm looking for ideas. Thanks.
  4. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    The m7ds may be a great rear speaker, but really they're simply a budget version of the 77ds, which is what I think you're talking about damtom, £100 at Richer Sounds, right?
    Fantastic speaker. If you can still get a pair, then they're well worth consideration. I say consideration because you never know how they'll match your other speakers, so you might want to check that out.
  5. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
    I have a pair of Mission 70ds rears. I auditioned them against the 77ds and heard no difference so bought the 70ds and saves myself 100quid.
    Mission 70ds
    Does anyone know what the difference is between the 70ds and the 77ds?
  6. mansell
    mansell
    Feb 11, 2002
    914
    28
    Bristol
    +39
    DR ROCK
    I use the gales cables from Richer's for my M72's
    Have you bi-wired you M72 front's yet ?
    if so what difference have you noticed ?
  7. Guest
    I've a couple of pairs of NS-E80s so I'd be keen to know what the original poster thinks of the Missions - assuming he went ahead.
    Mike.
  8. mancubas
    mancubas
    Jan 8, 2002
    514
    Derby
    +7
    Would u recommend using the following cable with 77ds.
    QED Micro :-
    Spec
    99.999% Oxygen Free High Purity Copper (OFHPC)
    Low Density Polyethylene insulation
    Construction - 2 x 1.25mm2 conductors.
  9. damtom1
    damtom1
    FLIMBER...no problem,i,ll keep you posted.Richer sounds in Brighton have,nt got any at the moment.I,ll probably order from their website.
  10. Timh
    Timh
    Sep 14, 2000
    5,170
    3
    3
    Altair-4
    +285
    I also have the 70ds from Rs, had them about a year now, they are a steal. :)
    If you turn them upside down you can also turn the badge, just be careful you dont snap them, use a small screw driver to prize them out.
