mission 701's
Discussion in 'Home Cinema Speakers' started by mobily, Jan 27, 2004.
  1. mobily
    mobily
    Dec 30, 2003
    504
    Plymouth
    +3
    Hello all,
    I am moving house soon and I have an all in one hi-fi hooked up to some mission 701 speakers. This was my main system but I have bought a sony dav-s550 which I shall use for music, so the hi-fi shall be moved to the bedroom. However if I find the sony system unsuitable for music I shall try and persuade my girlfriend to get hi-fi seperates ;)
    My question is do you think that the mission's would be able to be placed on a shelf? They are relatively heavy and I wouldn't want them to fall off!. I know that this isn't the ideal scenario but the room is small and putting them on stands would take up too much room.
    Thanks for all your help,
    James :)
  2. ciber
    ciber
    Try AE301, it is quite small, but sound is big and nice
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I've got some, and they are sizeable speakers!
    They'll probably sound alright on a shelf as they're front-ported, so it's up to your judgment if you think the shelf is substantial enough for them.
