Mission 6.1 upgrade options?
Discussion in 'Home Cinema Speakers' started by ronsealdeath, Apr 8, 2003.
  1. ronsealdeath
    ronsealdeath
    I recently got into home cinema with a Marantz sr4300, tosh sd220e and a mission cinema 6 pack through my Sony TV. I used the amp and DVD with a mixture of different hifi speakers before the missions and the sound was ok (Pair of Heybrook HB1's, a mordant short ms10i centre and a pair of eltax floorstanders for the rears with no sub). I figured get a dedicated surround package with a sub, so i got the missions. Ok effects steering and rear effects are good but it doesn't have much bite to it. I basically have to upgrade to 6.1 or there's no point having the marantz,(I'm waffling a bit here guys so bear with me!) instead of getting another model 70 monitor off ebay (i've seen a couple), should i get a mission dedicated centre and put the other monitor as the rear, cos there's always loads of centres on ebay. If so which centre should i get and will it give the system a bit more attack and presence?
    phew sorry that took so long to say.:clap:
  2. Viker1
    Viker1
    If you want to stick with Mission look at the m7c2 (part of the m70 series). It will be a great acoustic match for your present Mission set up, and it is a very decent, and quality center speaker .
  3. rozzar
    rozzar
    Sep 29, 2002
    1,046
    41
    Braintree
    +23
    didn't the cinema 6-pack have the white speaker cones? i think the M7c2 would be slight overkill for that...I'd personally look for a 70c2...had 2 5 1/4 inch bass drivers, and the same tweeter thats in the 70s that you got in your package. shove the supplied centre to the rear centre. it shouldnt' be more than £50 really...Mission are so quick to discontinue stuff, that quite frankly its hard to keep up to date.
  4. ronsealdeath
    ronsealdeath
    Thanks for the tips, i have seen several of the speakers you mentioned on ebay, i'll keep an eye out for one going cheap.
  5. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    Depends what your future plans are ... if you plan to later upgrade the fronts ... get the M7c2 ... otherwise get the 70c2.
    Vikki
