missing terrestrial channels
Discussion in 'Satellite TV, Sky TV & FreeSat' started by mikeygg, Mar 2, 2005.
  1. mikeygg
    mikeygg
    i cant get itv1, channel 4 or channel 5. when i display all channels channel 103,104 and 105 are missing, any ideas please :)
  2. graham w
    graham w
    Same happened to me today,
    i just turned it off at the mains then back on and it was fine.
    It was snowing at the time which seems to affect the signal.
    Also 101 and 103 wer'nt regional until i connected the rf lead in,does this dend a signal to the box to change it as changed automatically?
  3. rasb0
    rasb0
    Dec 11, 2004
    251
    Bolton
    +4
    Same happened here on one of my two multi room boxes last night. I too rebooted the box (turned off at mains for a minute or so) and it all came back. Quirky! :rolleyes:
  4. mikeygg
    mikeygg
    tried that no luck tho :confused:
  5. waynewickenden
    waynewickenden
    Same here, i just waited for about an hour turned the box on did a factory reset, retuned and hey presto all channels were back to normal
  6. Bluevanman
    Bluevanman
    What message are you getting when you try to access the missing channels? If you type 103 into the remote does a little red bar come on screen saying channel unavailable? If so the card has not been initialised. a call to sky should sort out this problem.
  7. mikeygg
    mikeygg
    how ya do a factory reset? i foned sky but as i dont subscribe to them no more they cant or wont help iget al the other terestrial channels just not itv1 ch 4 and ch 5 :rolleyes:
  8. Davews
    Davews
    had the same problem [itv1], powered down for 2mins and powered backup all ok now?
    Strange.
    Dave.
