Missing product key for Win XP - what can I do?
Discussion in 'Desktop & Laptop Computers Forum' started by Triggaaar, Aug 21, 2005.
  1. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,008
    +1,135
    I'm trying to install a legit version on Win XP home, but the product key has been lost. Is there a way to get it from microsoft (eg - is the 14 digit certificate of authenticity on the case sticker unique, and can microsoft find your product key from it)? Or is losing the product key the end?
  2. The Dude
    The Dude
    May 21, 2004
    6,156
    Beverley, East Yorkshire
    +2,441
    you should be able to recover the license key from MS if you have the authenticity certificate... not sure how you actually go about doing it though.. :(
  3. The Dude
    The Dude
    May 21, 2004
    6,156
    +2,441
    are you sure it isnt on a sticker on the PC somewhere..? look underneath if it's a laptop.... you don't usually get the license key on paper if it's XP home.... unless you purchased it seperately...
  4. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,008
    +1,135
    Yep, I purchased it from someone on here. The sticker that would be attached to a new PC is on the manual. I'm sure the product is legit and never registered, it would have just been an oversight. Unfortunately, it's taken me 5 months to get round to building a PC, so a bit late for me to ask for the code now (although I have sent a PM).
    The authenticity certificate, with the product key printed on, is what I'm missing (green piece of paper, like a tax disk, but square). What I have is a sticker saying it is a certificate of authenticity. I'm trying to find something on the ms website, but failing.
  5. The Dude
    The Dude
    May 21, 2004
    6,156
    +2,441
    As far as I know, you have to phone ( yes, phone!) MS with your 14 digit authentication code, and they will send you the Product key, but charge you (10 or 20 $) for doing so....
  6. meansizzler
    meansizzler
    May 11, 2005
    7,723
    104
    London
    +316
    Well Microsoft say, that when installing windows you must install the sticker on the back of the PC saying that this machine is running a "Genuine Version of Windows", if not it would be illegal to run the machine, even if your windows is legal, guess the only thing you can do is purchase a new version of windows, which would cost you £65 for the Home edtion or £75 for the Media Center Edition.., what I would do is type the serial number into your phone/pda, that way you will never loose it...
  7. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,008
    +1,135
    Yep, I've just been through the section on lost product keys, and got the number to call (Mon-Fri). You get 2 calls of support free, and don't know about the charge for the product key.
    I'm also not sure where to say I got it from. Hopefully I'll hear back from Pulsar, and see where he bought it from.
    Thanks for your help.
  8. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    time to go for Linux or maybe MacOS:D
  9. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,493
    Birmingham
    +205
    The disks are not unique, so although you could probably find a key that works with that disk it would not be legitimate.
  10. Skunkpipe
    Skunkpipe
    This should have the product key on it - if not it's not a COA.
    You no longer get the green certificate paper - I think Win2000 was the last to get this, all copies of XP come with now is the sticker that should be attached to your machine when you purchased it
  11. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,727
    71
    Land of the Living, Essex
    +35
    There is a nice key generator around, it takes ages to generate a key though and you have to play with the registery.
  12. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,008
    +1,135
    Just pulling my jaw off of the floor.
    I've just called Microsoft, told them my situation, and with nothing from me, they've just given me a product key. I'm gobsmacked. Thanks microsoft.
  13. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,727
    71
    +35
    Really? I've never tried that, I lost my key ages ago and was at a loss of what to do, it never occured to me that I could ring MS, I didn't think they'd be that accomodating
  14. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,008
    +1,135
    I hoped that they may be able to use the 14 digit number I had, but they didn't even ask for it. They just took my name and email and gave me a number. I told them I bought the software with all the individual components of a PC, which isn't quite correct. I'll check where it really came from with Pulsar when he gets back to me.
  15. KoThreads
    KoThreads
    Jan 18, 2005
    3,012
    +179
    Hijack thread for code help.
    My main pc runs my OEM copy of Win Home (from ebuyer about 2 years ago) and up till now I also had it installed on 2 other pc's built after various upgrades, authorised by the phone system where you enter all those bloody numbers.
    Over the last few weeks when updater has found new updates it's asked to validate Windows. It validated the main pc fine, but it won't validate the other two.
    I guess it's because my license is only for one copy. What is the best way to go about changing it. Would Microsoft charge me less for 2 licenses than the current ebuyer price for two more copies (which I really begrudge paying as i've already bought it once)
  16. meansizzler
    meansizzler
    May 11, 2005
    7,723
    104
    London
    +316
    You need 2 licenses/2 legitamate serial numbers, try phoning microsoft and ask them where you can purchase it from or just go on ebay and buy two unlicensed copies of windows, you cannot update windows without a legitimate serial number which is only registered on the PC your using it on..
    They introduced them new security checks a month or so ago and for some of use it is a pain in the ass, cannot even download windows media encoder without validating windows, still it is only £75 out of your pocket for a legit version of windows, which is well worth it considering the OS is the most important part of your system..
  17. Rambles
    Rambles
    Jul 14, 2004
    7,664
    UK
    +896
    LINK
  18. KoThreads
    KoThreads
    Jan 18, 2005
    3,012
    +179
    Cheers Lisa
    Thank God i'm not the only person MS think is a crook
  19. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,008
    +1,135
    I used to think they were, but today they're my best friend. After you guys of course.
  20. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,864
    Londoner living in Doha, Qatar
    +139
    nevermind. :)
  21. meansizzler
    meansizzler
    May 11, 2005
    7,723
    104
    London
    +316
    Does not work anymore ...
  22. Rambles
    Rambles
    Jul 14, 2004
    7,664
    UK
    +896
    Hmm, well, don't know about the crack, but I reckon that disabling the plug-in might still work...... ;)
  23. meansizzler
    meansizzler
    May 11, 2005
    7,723
    104
    London
    +316
    Nope, you just get a screen telling you that you need to validate windows, and that you have to accept the active X control and allow it to run, of course since you disabled the plugin the active x control won't show so it's a no go...
    It says somewhere you can purchase a license online but when I try it says it's only available to people who are known to have invalid codes, guess i'll just buy a copy off ebay for £75 when I buy my new case,
  24. Rambles
    Rambles
    Jul 14, 2004
    7,664
    UK
    +896
    You tried this?
  25. meansizzler
    meansizzler
    May 11, 2005
    7,723
    104
    London
    +316
    Yes that's what I was talking about?...
  26. Rambles
    Rambles
    Jul 14, 2004
    7,664
    UK
    +896
    OK, just checking... sorry it doesn't work, you trying to activate or get updates?
  27. Dreamdog
    Dreamdog
    Oct 31, 2004
    59
    +7
  28. meansizzler
    meansizzler
    May 11, 2005
    7,723
    104
    London
    +316
    Trying to get windows media encoder, any chance you can email it or something...I can give you access to my webspace so you can upload it to...
  29. Rambles
    Rambles
    Jul 14, 2004
    7,664
    UK
    +896
    Yeah alright - pm me instructions...
  30. meansizzler
    meansizzler
    May 11, 2005
    7,723
    104
    London
    +316
    Thanks But I'm downloading it now from microsofts site now, they must have two mirrors, one that asks for validation and one that does not...anyway Lisa, did you try any WMV encoding yet..?
