Missing Panasonic Remote
Discussion in 'Home Cinema Control & Remote Controls' started by MrWibbleman, Apr 17, 2005.
  1. MrWibbleman
    MrWibbleman
    Dec 10, 2004
    I have just brought an ex-demo Panasonic TX-32PM11. Haggled a good price as it didn't have the remote (£350). Set-up the TV last night with only one problem. The input (eg AV1/RGB) appears in the top left hand corner. Reading another thread on this site, it will simply clear if I press the info button on the remote.
    If I buy a programable universal remote, will it have this function and could I enter the menu system on the TV? Or, should I try to get hold of the right panny remote? Also, for either answer, where is the best place to get a new remote from?
    If a programable remote is the better option does anyone have any recommendations?
    I also have a Toshiba DVD player, Sky+ and a Yamaha amp.
    Any help would be most welcome...
  2. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
    I got a replacement for my Panasonic TV from here
    Not an origional one but a fully functioning replacement. :)
  3. Ryderage
    Ryderage
    Feb 1, 2005
    75
    search the web, find out the 'model no.' for the remote control. Buy it from ebay. I got a 3 items from the dixons 'small store closures' they all had remotes missing, I replaced all of them for under 20quid inc. delivery. Hope it helps.
    Rikki
  4. MrWibbleman
    MrWibbleman
    Dec 10, 2004
    Okay I have made some progress. By programming my Toshiba amp remote with a Panny code, using a random button I managed to switch of the input signal message that appeared on screen.
    So, the new remote, I like the ebay idea but I can't find anywhere on the net that lists the model of the remote for my TV. Any ideas folks?
  5. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    Bradford, West Yorkshire.
    +324
    I've got a decent used one in my box of remotes.
    Yours for a tenner. :thumbsup:
    Let me know if you want it.
    A. Dork
  6. MrWibbleman
    MrWibbleman
    Dec 10, 2004
    Is it the correct remote for the TV? If so I will definatley have off you for a tenner...
  7. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    +324
    Pretty certain it is. EUR511210 if my anorak brain remembers correctly.
    Can't check 'til morning though.
    I'll let you know.
    A. Dork
