Missing guide data for some channels (BBC4 etc).
cdldt
Is this for MCE2005?
If you use a London post-code (e.g. SE1 9QQ) and choose Crystal Palace, you will get more complete guide data.
mark.carline
No its in Chester, Cheshire - CH4 8AZ
I guess i cant use a london postcode as we have regional programs round here.
I did give me a choice of three transmitters to use from when I installed it.
I think I chose the last one - "Winter Hill B"
I might try and choose one of the other two and see if that fixes it.
kolabere
Mark doesn't that Aussie thing scanBDA or something (sorry to be so vaque not at home at the moment) tell you which is the 'best' transmitter.
Or as Temujin says - manual listings.
cdldt
The problem with manually adding listings is that Media Center occasionally "forgets". Are have Microsoft finally fixed that bug?
mark.carline
kolabere said:
.....doesn't that Aussie thing scanBDA or something tell you which is the 'best' transmitter.
Thanks - Does anyone have any idiot proof guides on how to use this in the uk ?
Does it mean that when I am given a choice of three transmitters to use, by picking one of them then the actual TV signal is pulled from that transmitter ?
I thought it was just for the guide data (thats why it asks for my postcode).
cdldt
You need my modified version that I put on the Hauppauge forum.
No. The transmitter selected just affects what guide data you receive. Media Center will still scan all frequencies and use whatever it finds.
kolabere
Thanks Chris, I didn't realise it worked like that.
mark.carline
Thanks for that utility!
I have just ran it and it seems to do alot of scanning but then crashes and writes the following event to the event log:
Faulting application scanchannelsbda_2-3a.exe, version 2.3.0.0, faulting module scanchannelsbda_2-3a.exe, version 2.3.0.0, fault address 0x000104e5
Here also is the output files:
output.txt
- This is the information shown in the dos box
ScanChannelsBDA.log
- This is the log file it produced
mark.carline
Fixed it !!!!!!!!!!!!!!
Just resetup the TV signal and channels and it gave me the following list of tranmitters to use:
- Emley Moor
- Winter Hill
- Winter Hil B
When I was setting up MCE I was selecting "Winter Hill B" (not sure why). I then changed it to "Emley Moor" and it found "BBC Yorkshire" which isnt my region.
Finally I changed it to "Winter Hill" and low and behold its found BBC North West and also it has a complete guide data for all the channels !!
Similar threads
