Missing free space % on Sky+
Discussion in 'Sky Digital TV Forum' started by Scapegoat, Nov 19, 2004.
  1. Scapegoat
    Scapegoat
    Nov 19, 2004
    2,583
    Leeds
    +130
    My Sky planner is displaying less free space available than it should. With no programmes at all on the planner it displays 96% (you can actually see a small section of the bar is in a different colour).
    I have performed a number of resets and a software download - but have had no success in making this available again - Any ideas?
    It seemed to happend when a programme failed to record - when the failed programme was deleted (the 'i' said 0% used though) it didn't seem to clear the space.
    Finally more recently I have more issues with programmes recording poorly i.e. when playing back the picture freezes and the only way to clear is to exit and re-start from the planner using the user defined minutes and edging forward minute by minute until it plays again. Is anyone experiecning this?
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    No, I'm not. If you have nothing on the drive, go to the "hidden menu" (Services, 4, 0, 1, Select), then you will have the option of re-initialising the planner. This might do the trick. If it doesn't, it sounds like your hard drive may be about to fail.
  3. dsk19s
    dsk19s
    as to what nick said phone sky + tech sounds as if you need a planner rebuild quite common..
  4. nostro1
    nostro1
    Scapegoat sounds like your hardrive is on the way out.
    Exactly the same thing happened with me, you can try a complete reset 4, 0, 1 seclect and then 8, this will reformat the drive so you will lose all your programs.
    I am now on my 4th replacement Sky + box but one tip the engineer gave me was to switch off the Instant rewind. This saves a lot of mileage on the hard drive and thus extend its life. Hope it works.
