mikej
Yes - if you check the news article I posted above, you'll see the UHF channels 54-56 have been bought by EE in order to support their 5G expansion plans. COM7 (UHF 55) is due to be switched off by June 2022 at the latest, although EE could request it sooner (with 3 months notice) or Arqiva could even end it for commercial reasons before June 2022 if they wanted.
The UHF frequencies in the table for the Crystal Palace transmitter match those shown in your TV signal strength photos above, so I would say that's the transmitter you're most likely to be aligned to, in which case that is indeed an excellent coverage prediction for COM7 and perhaps further proof that you have a Group A aerial which isn't capable of picking up COM7 on UHF 55.
So I guess that is an indication that you should be able to receive COM7 with the right (wideband) aerial, but the info in those tables is just a prediction and there are also other factors that may affect the signal strengths you receive such as the height and location of the aerial, the state of your internal and external cabling, nearby trees, buildings etc. For the sake of receiving those COM7 channels for between 3 and 6 months, I still wouldn't bother upgrading the aerial, personally.
