Missing CBeebies on my XP MCE freeview install
Dunkwho
PANIC !!!
CBeebies has disappeared from my channel line-up :eek:
Anyone have any similar experience or suggestions to fix? I've done the obvious (switch it off and on again, full a full add channels, check to see if its become disabled in my channels part of guide setup but its not even there) with no improvement ... this is causing some concern amongst the family with a small 19 month old running around :) Clearly this isn't a gross problem for everyone because I've not found any similar reports (or maybe no-one else has kids ?). I noticed that "The Red button" was in the station list at 301 before I started trying to solve the problem so I believe my machine is getting station line-up changes correct.
See my sig for the full setup, basically its a pretty straightforward machine with two blackgold PCI freeview cards (not the newer twins, 2 singles). Never (knowingly) suffered anything like this before :(
Duncan
Dunkwho
Update : another scan for new channels has sorted my problem. 2 new channels were found ... one of which was CBeebies, not sure what the other one was.
Duncan
nvingo
FYI some software doesn't correctly find "off air" channels, which Cbeebies is daily from 19:00 to 05:00. If that corresponds with your re-scan periods could explain it. The other channel then might be CBBC with similar time-share. Does it keep BBC Three and BBC Four (the nighttime share with those) when you scan during daytime ?
