Mismatched cable length from pre to power amp - is it OK?
theo cupier
I'm upgrading from an integrated amp to a pre/power combo, with a separate AV processor, so I will end up with:
processor -> power amp (for rear and centre channels)
and
processor ->pre-amp -> power amp for front channels of 5.1
I need to route the processor (Yammy E800) via the pre-amp since all my audio sources are connected to the pre-amp and I am using a single 5-channel power amp.
Question:
Do I need the total length of interconnect between processor and power amp (whether direct or via pre-amp) to be the same for all channels? Ie:
processor ->2m-> power amp mixed with
processor ->1m-> pre amp + pre-amp ->1m-> power amp
Would it matter if the direct channels were shorter than those routed via the pre? For example:
processor ->1m-> power amp mixed with
If I could get away with connecting like this, it will save me a little money since I only need to buy 5x1m interconnects to add to what I have already!
Any advice greatly appreciated.
davehk
You don't need to match the cable lengths. Time delays are minuscule (the signal propagates at about 180,000,000 metres/sec, and with those cable lengths reactive losses are so small that the difference will be insignificant.
Mark Grant
Hello Theo,
You will be fine with those lengths :)
If front left and front right where hugely different lengths that might not be ideal for music, but you will be OK,
Mark.
theo cupier
Thanks guys. I thought as much but better safe than Swedish (as my father used to say) :D
Mr Grant - as soon as I've got my new AV rack sorted out I'll be on to you for some more of your fabulous cables :thumbsup:
Theo
