Mirror DVD-RAM discs
Discussion in 'Blu-ray & DVD Players & Recorders' started by narabdela, Jul 31, 2003.
  1. narabdela
    narabdela
    Nov 25, 2002
    270
    Glockamorra
    +4
    Anyone know of a source for these other than SVP whose ordering system seems to be seriously ****ed up at the moment?
    :confused: :confused:
  2. malcom
    malcom
    Aug 25, 2001
    526
    +4
    Hi narabdela. Before I place my next order with SVP I would be interested to know what problems are you having with their ordering system. Regards. malcom
  3. leeb
    leeb
    Jan 10, 2003
    880
    28
    Melton Mowbray
    +52
    I placed an order with SVP last week without any problems.
  4. malcom
    malcom
    Aug 25, 2001
    526
    +4
    I placed an order a couple of weeks ago and one item in their stock had changed from tubs of 10 to tubs of 25 so they sent me the 25 as analternative which meant that they gave me 15 extra DVD-R discs at no extra cost to me. Very nice of them. Sadly though they made a mistake on the other part of my order and sent me some +R discs instead of -R.
    They quickly replaced them for me. I felt bad for them really having done me a favour with some free discs they then screw up and cost themselves the postage to replace the wrong items.
    I was wondering if narabdela was having similar administration problems!!. Or if the problem was technical of some kind. I have the highest regard for this company. Everyone makes mistakes at some time. This was the first time in nearly 18 months that I have been buying from them. Not at all bad......
  5. narabdela
    narabdela
    Nov 25, 2002
    270
    Glockamorra
    +4
    Won't accept any debit/credit card I throw at it.
    NO. I don't have any credit problems.
    YES. I have triple checked everything.
    Never had any problems with them before.
    :mad: :mad:
  6. malcom
    malcom
    Aug 25, 2001
    526
    +4
    narabdela. I have never had to use a credit card with SVP. With SVP you don't have too. Select payment by cheque. Use your cheque guarantee number and the orders are completed and dispatched very quickly. 4 - 5 working days from posting. Hope this helps. Malcom.....
  7. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    Hi Leeb (or anyone else with a Toshiba rdxs30)
    Are you useing SVP's mirror Ram's on your Toshiba?
    If so , have you tried useing the disks on other DVD players with any success?
    General Panic
  8. leeb
    leeb
    Jan 10, 2003
    880
    28
    Melton Mowbray
    +52
    Hi General Panic,
    Yes I've used about 7 svp mirror dvd-ram discs without any problems, just need to format them using the rd-xs30 which takes about an hour. I haven't tried them in any other player but I don't think they'll work other than in some new Panasonic ones. I have been able to open and play the videos on my pc (which has a dvd-ram/-r drive) using Powerdvd.
    Regards,
    Lee
  9. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    How long?!?!?! A UDF 2.0 format of a DVD-RAM on my PC takes about 2mins top with a DVD-RAM disk (Standard Panasonic/TDK types) and not much longer on the HS2. It only took a few minutes on the E20 as well. I always format a disk prior to use rather than just 'erase' programmes. Or are you saying 7 disks will take you an hour - which still equates to 8 minutes each? :confused:
  10. rowbos
    rowbos
    Jul 9, 2002
    290
    Minehead, UK
    +3
    Equally my E50 only takes a few mins to format a disc, and works perfectly with Mirror DVD-RAM and DVD-R...
  11. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    Thanks for that Lee. I did get a Panasonic RAM with the Tosh and thought it formatted a bit quicker than that as well but not a prob anyway. :)
    Panic
  12. leeb
    leeb
    Jan 10, 2003
    880
    28
    Melton Mowbray
    +52
    I am correct :) Just looked in the manual and for a dvd-ram physical format it takes about 70 minutes per disc. Have to do a physical format because the svp mirror dvd-ram discs are not recognised when first inserted into the Tosh. The caddied dvd-ram that came with the Tosh read fine without any formatting.
  13. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    Oh I see. I have to admit I have never checked the 'Execute Physical Format' option in the DVDForm RAM utility as I've always found a standard quick format to work. That said my experience of RAM disks is limited to Panasonic (which come pre-formatted) and TDK and Maxwell that just required the standard quick format.
    Does the Toshiba have an option to format without conducting a physical format? Only ask out of interest because the E20/HS2 (and I presume the E30/50) have only ever been able to do a Quick Format.
  14. leeb
    leeb
    Jan 10, 2003
    880
    28
    Melton Mowbray
    +52
    Ah, yes it looks like there is an option for "dvd-ram logical format" which is much quicker than the physical format I've used. Have to admit not trying that on the mirror discs, will give it a go and see if it works!
    Also, having taken the lid off my Tosh I can confirm that the dvd drive unit is infact made by Panasonic!
  15. leeb
    leeb
    Jan 10, 2003
    880
    28
    Melton Mowbray
    +52
    Ok, it IS possible to format a new mirror ram disc using logical format, and erm, it took about 10 seconds! :blush: Thanks for the info Rasczak, will save me some time. :smashin:
