mleonard79
Hi Everyone,
I've just bought a Mirai DTL522P100 for my brother for christmas. Could anyone who has this set help me with what the best settings to get the best picture are for this? I've never set up an LCD Tv before and I know that sometimes you need to really mess around with the settings to get it right.
I can't get to the display menu to adjust the brightness etc - it seems to be disabled or something. The book tells you to press menu and scroll until you get to it but the picture that matches up to it is just bypassed every time I do this. Any ideas how I can get to this menu to adjust the picture?
The set is hooked up to my sky+ box at the moment while I try to get this right but will be hooked up to a normal sky+ box, a PS2 and a PC when my brother gets it. Do you think I need to buy a better scart lead to get a better picture - it's just whatever scart lead Sky supplied that's hooked up to it now - is this good enough?
I've changed the settings on my Sky+ box to 16:9 and from PAL to RGB (I think that's helped a little.) Any help on how to get it right much appreciated. Thanks.
Regards
Michelle
Regards
Michelle
