Minority Report R2
Discussion in 'Movie Forum' started by Britcitchris, Feb 12, 2003.
  1. Britcitchris
    Britcitchris
    Jan 11, 2003
    112
    19
    Nr Dereham
    I have just watched my copy of Minority Report and for some reason I can only seem to play The Dolby Digital soundtrack. When I select the DTS soundtrack on the film menu and press the button for DTS on my remote (for the amp), I get nothing but silence. Has anyone else noticed this?
  2. Family Guy
    Family Guy
    Have you listened to DTS on any other discs? Sounds to me as though you don't have dts output set up on your DVD player....mine played fine in dts, though the DD track is better.......(flamesuit on)!!!
  3. Britcitchris
    Britcitchris
    Jan 11, 2003
    112
    19
    Nr Dereham
    You raised a good point. It is a very early on dvd player - first generation possibly and it may not support DTS. Somehow I thought it would not matter as I thought it would pipe the DTS score via the optical cable to my amp that DOES support it and I would be ok. Will have to sound test some other discs....
    Cheers for the thought.
  4. nwgarratt
    nwgarratt
    May 5, 2002
    26,341
    +2,845
    Have you got DTS on the front of the player? If it is not there, then I expect the player cannot send the DTS to the amp.
  5. Family Guy
    Family Guy
    Ditto - if the player does not have the dts logo on the front, then you won't hear any dts tracks at all. Time for an upgrade methinks....All todays players support dts. Try the superb Toshiba 220 - £130 from HI FI Confidential in Victoria and plays everything....though I'm sure some forum members will be able to point you to cheaper sites.
  6. perrdl
    perrdl
    Jul 29, 2002
    357
    19
    Worcester
  7. Family Guy
    Family Guy
